My dealer has offered to buy my two years old Beovision 7 40” MKIII+BeoLab 7.2 for a value of 7.000€ if I buy a new one. Do you think it is worth to change to a BV7 MKIV or to move to a new BV10 also 40”. Also there is the possibility to update the mkIII with a DVD-HD and a BluRay but the panel will remain 50Mhz compared with the 100mHZ of the MkIV. Regarding the quality of the sound, my nowadays set up include 2 BeoLab6000 in the front, 2 BeoLab 3 in the rear and a BeoLab 2, so how it will be the sound of my setting up with a BV10? Is there any big difference in quality panel between BV7 mkIII versus BV7 mkIV
In the case I decide to change to a MkIV, do you think it will be better to change the BL 7.2 to a vertical BV 7.4 according my loudspeakers set up?
