BV7 MkIII and DBox2, AC3 with S/P DIF
Hello,
i have a problem to digitally connect my settopbox Dbox2 to the BV7.
I want to use the digital AC3 sound of the box and therefore i have connected the box via scart (AV1 for the picture) + spdif (for the sound). I had to convert the optical signal of the box to an electric one (cinch) for the BV7. How am i able to tell my BV7 to use the sound of the spdif? In the options menu it is only possible to select spdif when HDMI (A-D) is selected (!).
Thanks for help
Regards
TS
You don't have to. If there is SPDIF signal detected the Beo 7 switches over to SPDIF. Works just fine
thanks, but it does NOT work in my case ;-(
any other idea?
thanks
ts
What D-Box software do you use (Neutrino/Enigma)?
There should be a system setting, audio/sound - use ac3 default output...
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
In that case you probably don't have a SPdif signal (I presume you connected the right input)
 Check if the box is indeed sendig optical SPdif  (you see a led flashing), if so check if there is an electrical spdif signal (see wikipedia how to do that)
succes
the box sends an optical signal => i can see thee red light.. When it is true, that the BV7 notices when there is an electical signal the problem has to be with the transformer or the electrical cable. can you give me a link where i can read how to check if there is an/ the right electrical signal? i have searched for it but nothing found...
thanks a lot
TS
Just to double check: at the moment you get no sound at all while chosing a tv station that is sending ac3?
If you still hear sound, it is stereo only and your box is not set to AC3 - see my post above.
Ralf
Danke für den Tipp Ralf, leider wird bei der Umschaltung an der Box auf AC3 der Ton am TV ausgeschaltet ;-(
Nur über den Scart-Anschluss wird Ton, dann aber leider nur 2-Kanal, über den BV7 ausgegeben. Über den elektrischen S/P dif-Eingang des BV7 kommt bei Umschaltung der Box auf AC3 - damit optischer Ausgang der Box mit AC3- leider nichts an..
Gruß
TS
