Hi all you clever people.
I am trying to connect my BV7 40 MKII to a BC9500 via a BL611 converter but there is no sound.
Having followed the user guide, I can control the BC9500 via my BEO4 and the BV7 recognises the connection as it displays the source and I can hear the speakers click on. For example, when I press CD on the BEO4, the CD starts playing and the BV7 displays CD. However, I get no sound at all, the BC9500 starts up and the ‘mute’ sign is lit by default, I then unmute. Changing the volume up and down does not make a change to either the volume level on the BV7 or BC9500.
I have tested that sound does come out of the BC9500 by connecting the Beolab 7.1 directly, so I know it is not the BC9500 itself and I get sound out of the TV when on DTV.
The connections are as follows….
Masterlink cable from BL1611 to BV7
Datalink (7 pin) from BC9500 to BL1611
Powelink from BC9500 powerlink input 1 to BL1611
The TV has the speakers so I set v.opt to 0 and a.opt to 2.
I made sure the BV7 and BC9500 were disconnected when I attached the cables and connected the BL1611 once the BV7 and BC9500 were in standby.
Any clues?
Dan
