BV7 IR Transmitter
I have my ATV and BV7 connected properly. I see the IR transmitter is working correctly (I used an old digital camera to ensure it's sending a signal), and Apple TV is selected in the connections list. The issue is I cannot seem to control the ATV with my Beo4.
The ATV is flashing to show it receives an IR signal from the BV7, but it just doesn't respond. Of course using the remote that came with the ATV works fine.
Any thoughts?
Duplicate post.
Stoobie
Exeter,
Devon,
UK
Thanks SO much! Worked perfectly 🙂
Brilliant.  It is always good when it is an easy and free fix.
Stoobie
Exeter,
Devon,
UK
