BV7 Freeview upgrade
I have had a search for this but can't find a specific answer.
My BV7 is aboutt 14 months old, is the Freeview upgrade available, and is their anything else I should consider upgrading.  I read somewhere that the HDMI is not compatible with certain encryption.
Thanks in advance
I don't know whether your model can accept the Freeview upgrade but note that if fitted it is permanently assigned to the SAT/DTV button so you will only have one STB-C controller available to you (via the V-AUX button). Depending on your configuration, that may be something to consider.
Yes, it will be DVBT upgradeable.
I upgrade mine and the picture is superbe with the tuner. Much better than with my sky box.
Also it sends the picture in the correct format to link rooms.
Note that the current Freeview tuner cannot receive HD channels. A new HD capable tuner will be available soon. So you might wait for that.
p.
Thanks for all your responses.  I'll hold fire for the HD version!
