BV7 FORMAT 0 "help"
Dear All,
I have a BV7 on which I recently attached to a Panasonic PT-AE4000 projector. When I press "Format 0" the electronic curtain works then TV shows "wait" then nothing 😭   finally picture comes back on BV7.
No signal on projector !
I tryed on different sources DTV, VMEM... and it's the same problem.
Any idea ?
Matthieu
Just pm your model of BV7 and I'll see if I can help.
Have you set cinema timing in costumer service menu??
Hi Anderson,
I know how to access to the Service Menu but I don't know where are the "Cinema Timing" menu.
Which setting should I enter ?
Thanks,
Mat
Anders is talking about customer service menu. Press MENU - down to OPTIONS - press RED - GO. Now you should have the customer service menu. Now press ADJUSTMENTS - here you should find cinema timings.
Please tell us what BV7 you own. Sounds like your BV doesn`t detect the projector. As far as I know the Pana is a full HD projector. If you have a BV7-40 MKII it`s max. resolution is 1366 x 768.
Stefan
Thanks for helping me.
My BV7 is type 9312 with latest software and HR READY KIT installed.
The projector is FULL HD (Panasonic PT-AE4000) but i tryed to "FORMAT 0" the DVD and my STB (SD source) and the symptoms are the same.
Mat
Mat
I don`t think it depends on the video source. The BV7 sends a 1366x768 or 1280x720 picture and maybe your Panasonic "expects" a 1920x1080 picture. So they won`t "understand" each other.
Sorry I don`t know what a "9312" is Is it a BV7-40 MKIII (withh 4 HDMI inputs) or a BV7-40 MKII with single DVI input?
Stefan
My BV7 is MKII with single DVI input.
I made cross checking:
1.connect a standard lcd PC screen to BV7 => same symptoms as the projector no picture
2.connect a PC to the projector with low def via VGA => the projector accept the input with no problem.
According to these test the problem come from BV7, no ?
Mat
I had the same problem with Panasonic PT-AX200 a couple of years ago. The projector didn´t work with my BV 7-40 MK1.
I changed the projector to Sanyo PLV Z5 and everyhing worked as it should. So I guess that BV 7-40 MK1 and MK2 won't work with Panasonic projectors.
Mr Andersson might know more about this subject because he gave me valuable advice in the old forum!
Regards
This is not a good news as I do not plan to change my projector soon (4 weeks only).
But it is strange as I tried to connect the VGA of BV7 to a standard LCD computer screen and it should work but it doesn't.
Mat
