BV7 40 MKIII / SW 4.24 problem
moxxey:
Got my BV7 last week and its turned off twice in the last few days.
I'm also running skyhd via hdmi with scart connected.
John
I think I want to buy the North American versions of B&O- they get HD sound- we dont. We get the crash to off - they dont- its hardly fair
Razlaw:
Razlaw:
I wonder if the 4.24 North American version is different? I have no problems with it.
Razlaw, have you read the entire thread? Do you have an STB connected via HDMI?
 I thought there were  problems unrelated to an STB such as the white flash you complained about early in this thread.
And if by STB you mean a satellite box, yes, I have a STB connected via HDMI to the BV7, and both work fine . If by STB you mean something different, no I do not.
Are you controling your satelite box via the Beo4/5 remote ?
/Weebyx
Yes I control the satellite box and the DVR function of the satellite box with the Beo 4. The Beo 4 works fine for turning the box on and performing all basic operations on it. The Beo 4 will not turn the box off. The box, however, has an internal setting that can be set to turn the box off after a period of non-use. Thus once the Beo 4 turns the TV off, the box will turn itself off after 4 hours of non-use.
hi all i had last night was problems and its annoying me
i had waht i call the HDMI sync drop out a few times where i can hear sound but get snowy screen, at one point the tv showed as being off but the screen was still snowy.
Also if i remove the scart lead control of sky hd via the STB is all over the place
were all these issues not a problem in 4.17 or did the stb box weird behaviour start with 4.24, i hope a fix is done soon as i dont want to go to 4.17 then back up again to the new ones.
i cannot believe B&o are selling the tv's still with duff software installed, i am waiting as i know there is a problem but imagine if you just bought that and got it home and it crashed how annoyed woudl you be lol
well lets hope they test properly this time
I think it happened to me yesterday. My digibox uses HDMI, even though i wasnt watching HD TV. After the restart, my stand wouldnt move!!!!
I had to unplug it and reset the TV! This is on the BV7-40 with te latet sw installed; are we talking about the same issue?
