Bv7-40 mk111 shuting down
I've seen that (shut down), twice. In fact, I thought it was the TV overheating, but the second time it did it after less than an hour, so ruled that out.
However, that was ages ago and hasn't happened since the recent sw upgrade. As it's nearly six weeks ago, and hasn't done it since, I've not even bothered reporting it.
My TV seemed to just look like it had switched off, although the Sky HD box was still on. The only away around it was to turn off at the mains and then turn back on!
Hello
I had also the problem, that my Beovision 7 40 MK III shutted down itself. The problem was the IRr-two-way communication of my BC9500. Since I covered the IR-emitter of the BC 9500, the problem is solved.
Regards
Wallace
I have a BS9000 linked to the 7-40 (Mark III) and I had problems with the BS9000 shutting down mid play but not the BV7! Sorry to confuse matters even more but it is starting to sound like masterlink connection and/or remote issues rather than faults with the TV or other product(s) installed. Have you experienced any recent power cuts? Also, do you use the A9 keyring? It took me ages to realise that every time I took the A9 out of my pocket and put it down it was often swithing products on and off! Couple of suggestions there anyway. Wish you all the best either way.
Simon.
Hej,
It`s a ML- problem. The engineer has to install the new sw 4.12 to the BV7, that will solve the problem.
I have had the same issue where my BS 2500 would not turn on when connected to the TV through ML.
trucker
