Hi there!
One og my family members have a 7-32 MK3, but because of hes bad hearing, he now bought a couple of rather high tech hearing aids.
The problem is, that when he connects the wireless box that comes with them to the headphone output, the speakers mute. Since his wife still needs the sound from the speakers, that doesn't work for them.
Is there some kind of work around, so they can each listen to separate volumes ?? -I have tried connected the box to the center speaker output not in use, but at a normal TV volume, the signal is way to weak.
Also tried connecting the box to the front speaker output, but then they will have choose who is gonna listen (speaker 1 and speaker 2 mode). It would be ideal if speaker mode 3 could output the center signal through both center and front output, but that doesn't seem to be possible either??
Hope this all makes sense and hopefully someone have that one magic solution 😊
