AndrewEcosse wrote:
Having given up trying to get my MacMini connected to my BV7 to talk to the BV6.
What were you trying to accomplish? I may have just ordered a PUC to accomplish same what you were trying, so hope that it may work?
AndrewEcosse wrote:
I've moved onto connecting a Gen3 AppleTV to the BV6 via the DVI using a HDMI to DVI adapter.... but I now get a flicker on the screen. About every 2 seconds the TV flicks. When it is not flicking the picture is perfect. The tv is connected as a link TV if that makes any difference to anything. Also in the connections menu I don't seem to be able to change anything??
I may have the same issue, but can live with it. When switching to my macmini (connected with hdmi-to-dvi adapter), I am getting a full-screen flickering for 2sec. After the 2sec, it disappears and all works well. I was told that it is just that these old BV models came from a time when DVI was still in early stage. But given that it is just 2sec and only when switching to the macmini, I am fine and can live with it. If you find a way thought o get rid of it, it would be appreciated if you can share back.
