marcus_m wrote:
The difference should only be parts of the software of the module. If you connect a PC or MAC, than the Panel identifies itself as BV4 via the DVI. But the Autodetection of BS3 does not work :-(
As it identifies itself as a BV4 doesn't mean that its done by the DVI module. Mayby it's done by the panel itself through the DVI module.
By searching through several circuit diagrams, it is also possible that the data lead in the DVI connector is directly connected to the panel itself.
That would confirm the theory that (special B&O) settings in the panel itself makes that the panel is recognized as a B&O panel for the whole range (D5....D11).
If the DVI module would be responsible for the recognizion, then there would also be for every different type of B&O panel a different type of B&O DVI module. While panasonic itself handles for all the different panels the same DVI module.
marcus_m wrote:
To make the panel fully BS3 compatible, I guess parts of the panel sw have to be modified as well. AFAIK there is an update tool available....
Probably that tool automates the procedure which probably can be done manually.
By the way I received today the original pana remote and at first sight the B&O panel responds to the service menu instruction. 😎
