BV4, BS3 plus Playstation 3
Could you take a picture of the screen in the BeoSystem 3 Connections menu for that particular input? Also, a picture of the Sound System menu when on the input with a movie etc... playing in the PS3.
There may be something obvious we're missing...
Hi Alex,
I don't have a photograph available, but my connections are as follows.
BS 3 HDMI into slot B, I have set this up as AV3 V-Aux, auto-selection NO, Sound Input HDMI, YPbPr NO. On the PS 3, under sound settings I have HDMI selected, Dolby Digital 5.1ch, DTS 5.1 ch, Linear PCM 2ch.44.1 Khz and Linera PCM 2ch 48 khz (I was unable to de-selcted the last two Linera options from the PS 3 options).On the PS 3 BD/DVD Audio menu, I have output format HDMI and Linera PCM.
I can manually select all five speakers, just not sure whether this is providing me with the best sound possible.
Regards
Keith
Here is my settings.
/Weebyx
Thank you Weebyx - With those settings do your rear speakers cut in automatically when you play a Blue Ray disc on your PS 3 ?
Yes they do.
/Weebyx
Weebyx,
Do you have your default setting for the number of speakers to use for video in your B&O system set to 3 or 5 ?
akeithj wrote:
Weebyx,
3, the rear speakers only turn on if i watch a movie containing DD5.1 or DTS, from my PS3 or Vista Mediacenter.
/Weebyx
