BeoMegaMan wrote:
not from what I understand and have seen. The BV4 has a seperate IR panel integrated into the bottom of the frame which is a new proprietary IR sync system (B&O purchased) to run the sync of the glasses. Plus naturally 3D can only be transferred via a HDMI signal which has also been switched out from the old DVI only outputs of the old BS3. If you can find a new BS3 only and a way to setup a modular IR sync then you would have a simple solution as explained...... it's not like the old 42/50/65's :)
Now this IS interesting if it is the case - and also puzzling why they would do this. The synch of the glasses is a pretty mundane thing - needing only 60hz per eye for the shutters (assuming 120hz framepacking mode, which Panasonic use) - and really no need for a 'specialist' solution. I wonder why they did this - the press release makes no mention of it - concentrating on the motorised stand, and I would have thought they would have done if they had introduced something new. My guess is that they have had to add a new emitter because the bezel would be in the way of the Panasonic one!
With regard to your other point, I assume (as I haven't done this yet myself as I don't have a 3D TV) the Beosystem 3 can output a 3D switching signal to an appropriate TV, and, as DVI is electrically compatible with HDMI, with the right plug on the other end (HDMI 1.4 3D connector), then there should be no issues for the system to work well. Again there is no mention of needing a different Beosystem 3 to drive the screen in the press release.
