Hi Team ,
Have aquired BV4-50 with the D8 pannel and a BeoSystem 2. The Plasma supports up to 1080i but I see that via component the BS2 only supports 720P . Since the BS2 also does not have DVI im unsure of it is at all possible to use the BS2 to get the 1080i signal I get from my HD tuner box to the pannel.
Any one know if its any way possible ?
I also have a Yamaha RX-V661 that I think might work but want to use BS2 if I can.
