BV4-50(D8) with BS2 MKII Help
Hi Team ,
Have aquired BV4-50 with the D8 pannel and a BeoSystem 2. The Plasma supports up to 1080i but I see that via component the BS2 only supports 720P . Since the BS2 also does not have DVI im unsure of it is at all possible to use the BS2 to get the 1080i signal I get from my HD tuner box to the pannel.
 Any one know if its any way possible ?
I also have a Yamaha RX-V661 that I think might work but want to use BS2 if I can.
Tricky. It seems as if you have the BeoSystem 2 MK ll 941x (?), but with or without DVI: HD-Ready is the best it can offer. You will need the BeoSystem 3 for Full-HD. There are HD-Ready kits (one w/DVI & one w/VGA/YPbPr) available.
Roger
Thats what I thought :)
The D8 maximum res is 1080I and would like to get that. Do you know of how to obtain the HD ready kit ?
They seem to (still) be available from B&O, so I would give your dealer a call and check.
Roger
Hi Roger,
Do you have the part # ?
Sorry for the late reply, but here you go:
HD ready kit - DVI
4368 (type no)
1436800 (part no)
290 (approx price €)
HD ready kit - VGA/YPbPr
4369
1436900
190
Roger
Roger wrote:
HD ready kit - DVI
4368 (type no)
1436800 (part no)
4369
1436900
190
Roger
Roger do you know what the HD ready kit - DVI actually do !
Is the DVI only a input - or is also a output ?
Do you have some more information
If you have a D7 (or later) plasma panel that can handle the resolution, you need to install the DVI-card into your BeoSystem 1/2 (slot 1) and this acts as a scaler for the panel. They do also offer a card with VGA/YPbPr connections.
Sorry if I do repeat myself - not sure I understood the last question properly.
Roger
I heard that there is a solution for BV5 to, or?
Yes, as long as the BV5 as a serial number higher than 18380842. Just order part no. 1436800.
Roger
