I have a BV3 28 at the moment which has Masterlink, stb controller and sockets for beolab speakers. What is the technical name for the speaker connections? Is it a Sound Module?
The reason i ask is that im eyeing up a BV3 32 and have asked the seller if the tv accepts beolab speakers to which he replies no. So should the BV3 32 come with the 'Sound Module'(speaker connections) as standard? If not can the speaker connections (Sound Module? 'or whatever its called') be removed from the 28 and fitted in the 32?
If the 'Sound Module?'(speaker connections) cant be swapped over, does anyone know the cost/part number of the bits i need to make the 32 accept beolabs?
Hope all that makes sense and thanks in advance for any advice offered.
Mark.
