BV3-32 question
Hi all,
Since a few days i have a BV3-32 (6 years old).
The image is very beautiful, except when it is about dark scenes.
See photo included , it's from the screen when i switch the Tv Off
And these lines can be seen on dark scenes
What do you think about ?
Zazou
You better get this checked, it could be tube failure.....
I'm afraid it's not good news.....
I saw the same thing on an Avant RF I wanted to buy so I rang B&O service. They said it's either the tube or the chassis and is rather expensive to fix. The quote was around $2500AUD + , so I didn't go through with the purchase.
I'm sorry you had to hear this. The best thing to do is to enjoy it as is or try to get a refund.
there should be an adjustment on the back of the tv when u take the back off think its a auto gain control, if u turn this the lines will go
Dam, I wish I knew about that if it works...
could you explain a bit please ?
when i take the back off, where is this adjustment button ?
Zazou
Be careful, there are parts that's dangerous to get in contact with, even if the TV is unplugged.
There is an adjustment screw, but in most cases only with temporary result.
Hi all,
Just to let you know : yesterday i received my BV3-32 back after repair.
and they changed the Chassis, not the tube.
Regards
Zazou
