The only issue I have is when I turn on the TV (should also start the Apple TV) half of the TV is green since the update.
If I press TV Apple TV then that fixes it.
I might have to reset the whole TV which is very odd to me.
I wonder if the software update was pushed out by b and o or android.
I have my TV button set to turn on the Apple TV and most times it signs out of Netflix. My Sony tv keeps all of this. When I start then Netflix it makes a noise like it’s starting house of cards and I’m not even playing that.
I wonder if it has something to do with the puc control maybe not turning the Apple TV off at TV standby which it should do.
I like the android interface. I would prefer it if you could move the “shelves”
I don’t think mine is that sluggish but I mainly use Apple TV interface solely because of Netflix.
The Netflix app does not work on the BV14 - well mine anyway
