BV14 and Beovision Horizon - any feedback?
Motion processing seems to be much improved in the update that came out yesterday. Anyone else discovered other improvements?
Hi Chris
Currently away in France until Tuesday and will be able to confirm more then, but yes it does. You need to enter the TV service menu and activate the BLGW. Then in the BLGW webpage ensure you untick legacy commands for control.
Stuart
Yup. Think I've done all that. Doesn't work. Also the LIGHT and CONTROL options rarely show up when I press LIST on the BeoRemoteOne BT. They appeared a moment ago, but have disappeared again. I also hate that there are loads of things in the LIST menu that I don't want and can't remove or edit!
Chris Hassell wrote:
Yup. Think I've done all that. Doesn't work. Also the LIGHT and CONTROL options rarely show up when I press LIST on the BeoRemoteOne BT. They appeared a moment ago, but have disappeared again. I also hate that there are loads of things in the LIST menu that I don't want and can't remove or edit! BV11-46, Beoplay A2, H3 ANC, Beo 4, Beoplay S8, Beosound Essence MkII
Hi Chris
Back from a mini break today and can confirm that the new TV's do accept LIGHT and CONTROL commands. I have a macro in the showroom for all on and all off which is Light 0 or Light 1. When I select the Horizon 40 on the BR1 list I can then highlight Light within List and simply press 1 or 0 respectively.l and it works perfectly.
Best regards
Stuart
Netflix worse than before on my BVH40
Netflix never ever works on my BVH (have been able to use it for 5 times now, only directly after new sw install).
I keep thinking that Netflix should be working properly, if only because it then play's 4k content, as my appletv is not!
Wishfull thinking and in line with recent discussions regarding spotify failure on the BS5 platform. Such a bad publicity for B&O.
My faith in the company is being tested heavily; many flaws in current directions.
But on topic again regarding BV: after last update picture really has improved a lot. I now find myself surprised on the bright and clear pictures it delivers. Also haloing is now so low I only notice it sometimes and then it is not as annoying as it used to be. Thumbs up!
I still encounter problems with Multiroom/NL part. Starting patternplay or normal music session on Moment does not activate the TV (and speakers), only works when booting up the tv first.
Other improvement might be the sound richness, if the tv sound was a little bit more powerfull.. but that might be just be the difference between BVH and BV14.. no software issue.
Regarding stability, also big improvemend. Dis crash only once after last SW update.
Conclusion after one week: still out the woods! Good job, please continue tweeking it till perfection!
Hi Chris
I had noticed that two of our TV were not displaying Light & Control. To retrieve these back into the BT remote I had to power cycle the TV's. hope this helps
Hi!
Is it possible to play music directly through the B&O app to the Horizon? Just like you can do with the BS1 och Essence? To get music in my living room today I have to start the music in the bedroom och kitchen and then use the BeoRemote to add (anslut) the TV to an existing source. It is a bit annoying as some times you just want music in your living room...
Best regards!
Soon...september update
