Motion processing seems to be much improved in the update that came out yesterday. Anyone else discovered other improvements?
BV14 and Beovision Horizon - any feedback?
Hi ChrisBack from a mini break today and can confirm that the new TV's do accept LIGHT and CONTROL commands. I have a macro in the showroom for all on and all off which is Light 0 or Light 1. When I select the Horizon 40 on the BR1 list I can then highlight Light within List and simply press 1 or 0 respectively.l and it works perfectly. Best regardsStuartYup. Think I've done all that. Doesn't work. Also the LIGHT and CONTROL options rarely show up when I press LIST on the BeoRemoteOne BT. They appeared a moment ago, but have disappeared again. I also hate that there are loads of things in the LIST menu that I don't want and can't remove or edit! BV11-46, Beoplay A2, H3 ANC, Beo 4, Beoplay S8, Beosound Essence MkII
Netflix worse than before on my BVH40
Hi ChrisI had noticed that two of our TV were not displaying Light & Control. To retrieve these back into the BT remote I had to power cycle the TV's. hope this helpsYup. Think I've done all that. Doesn't work. Also the LIGHT and CONTROL options rarely show up when I press LIST on the BeoRemoteOne BT. They appeared a moment ago, but have disappeared again. I also hate that there are loads of things in the LIST menu that I don't want and can't remove or edit! BV11-46, Beoplay A2, H3 ANC, Beo 4, Beoplay S8, Beosound Essence MkII
Hi!
Is it possible to play music directly through the B&O app to the Horizon? Just like you can do with the BS1 och Essence? To get music in my living room today I have to start the music in the bedroom och kitchen and then use the BeoRemote to add (anslut) the TV to an existing source. It is a bit annoying as some times you just want music in your living room...
Best regards!
