BV14 and Beovision Horizon - any feedback?
I've been very happy lately with the Horizon. Multi room working and all. But lately the TV has started to restart itself quite randomly. It all started with the latest update. Anyone knows why?
I sometimes hear a plop and the sound is gone and subsequently the television reboots or I have to switch it off. I had this issue a few times before the latest update, but it happened three times (in two weeks) since the latest update.
same here, complete random reboot has occurred four times after latest update, and counting
Tomorrow my BV14 will be swapped for a new one...for the third timeπŸ‘
what specific problem is it having?
surely its all software related?
More correct...my third set...no the current BV14 is the panel faulty...se my earlier post of the screen...
Would you mind linking to that? Couldn't find it in the first ten pages of your post history.
Good afternoon,
Concerning the halo around objects problem, could you check if the artifact also occurs with these high quality 4K video files? If yes, there is definitely a problem with the video processing.
These are sample files from the latest Canon camcorder and should be exempt of the compression artifacts of TV broadcasts or even Blu-Ray discs.
has anyone a clue when next software update for BV 14/Horizon is scheduled?
Next week
