QM153E.0.3.0.112 is also what I have.
I have to correct my post: Netflix is working only after pulling the plug ("cold start"). Annoying....
Anyone has a better trick?
Netflix is not supported!
Mine works sometimes but with black sub🙁title
i do not even see the netflix app installed on my horizon
I downloaded the app through the google play store and as said the app does not work. It shows message that Netflix does not work with this device. Maybe there is a work around but I use my AppleTV for netflix and works fine.i do not even see the netflix app installed on my horizon
I presume that the Beovision Avant NG as the same engine than BV14 and Horizon.
Do you think it works better or is it just that nobody bought it on this board ?
Just a thought if I ever get tempted (again) by an Avant (if the Oled is not what I expect - extra superior sound/excellent picture/7.500 € max on motorised stand 55").
The engine is the same. I suggest to wait until most of the issues are solved.
Well, I'm glad to see updates, indicates that they are working on the platform.
Karel, the software updates you mention - do they still show the release date as January 27?
I reset my Horizon to factory settings, which seemed to speed things up a little, and it has been running fine for a couple of hours tonight.
