BV14 and Beovision Horizon - any feedback?
was in Selfridges in London this evening....spoke to the B&O guy who runs the concession there - for what its worth he said that from what he understands, from speaking to some LG guys he knows, that the B&O/LG tv is more or less finished......and wasnt ruling something out in 3-4 months time......but that made the likely release to be last years LG panels, not the newer, brighter ones.......thought i'd share, however useless that info is....
My horizon seems to run better, less crashes, but still i am very disappointed netflix not working.
also has anybody succeeded connecting a wireless speaker like the new beosound 1?
it is supposed to be one of the features but we are waiting patiently
That still requires the "multiroom" softare update... release around week 10
Do you mean connecting a BS1 with your TV? So you could use it as a rear speaker or?
I am sure, that he means connect using NL in order to 'see' and use the sources of the BS1 on the tv and vice versa.
It is not possible to use the BS1 as a rear speaker.
Lots of bugs, even after the update of 31 January. This evening, I experienced two occurrences of the TV shutting itself down and rebooting through the 'Android' screen, via the grey 'Location' screen and the Apple TV screen saver. Also, various pop-up messages for no apparent reason. The new BBC iPlayer App is slow to start up, too, the Guide is still slow to build and various functions that should be smooth are jerky, such as the shut-down curtains. Not impressed!
However there is progress. The picture quality is better (and the side effects of the picture processing are much less). Stability issues are less. At least my Beoremote One BT has not lost connection since the update. However, we are not there yet (bass management, bug in programmable in buttons, Android pop ups every now and then, ....).
Does anyone have the BV14 40 inches?
Is this having the same issues ?
