BV14 and Beovision Horizon - any feedback?
Chromecast is something that does work on mine. The communication between iphone and TV via Chromecast (Deezer) is ok. However I would give it not 100% yet as bugs do appear. Sometimes you have to press the Chromecast logo on the screen of the iphone and select the Horizon to make the connection.
Thanks for your reply! What about Chrome cast video? Audio seems to work as well. But video seems to be the problem.
I have not tested this after the update. I will try.
So BV 14 55
Should I
Or
Shouldn't I ?
With my knowledge today I would wait a while. I was informed that there are plenty of issues to be solved.
I'd agree with that - if at all.
If you get annoyed by software bugs, i.e. early adopter stuff, then wait.....anyway all of this software will come to the Avant NG, so can't really side step it in any upgrade.....
All that being said, i'm warming to the picture quality of the BV14(55) that i have......and that as an avowed plasma fan, and love my 12-65.......different pictures qualitatively, but the 14-55 does produce an excellent picture, especially once the judder / motion smoothing nonsense is turned off.......
also depends on what you're coming from / expect.......for a step change, only the 2016 LG OLEDs achieve that.....they're jawdropping....
You should wait. The current Software is too buggy.
Youtube via Chromecast works on my Horizon.
Do you think they'll dare to increase the price of these televisions very soon? I hear they might.
It's going up in Nov by 8% I thinkDo you think they'll dare to increase the price of these televisions very soon? I hear they might.
