BV14 and Beovision Horizon - any feedback?
I dont seem to have the same problems, which is odd.....
that said, i dont think the update has fixed everything.....i lost sound again yesterday, same as happened a few times before the update......
i presume you have sent a "usage report" to B&O from the tv..........? think it helps them resolve these issues......
Original avant or new avant?Very happy I didn't replace my Avant yet.
Me tooVery happy I didn't replace my Avant yet.
2014 55"Original avant or new avant?
And skip the remark about the remote. I just had a failure in the connection between the remote and TV again after the TV had been shut off for more than an hour. There is a bug in the communication between TV and remote!
Hi guys,
Do you also have trouble using chrome cast? On my Horizon it doesn't seem to work. Furthermore I'm very happy about this new television. The software seems more stable after the update. Still work in progress though.
Regards,
R.
Chromecast is something that does work on mine. The communication between iphone and TV via Chromecast (Deezer) is ok. However I would give it not 100% yet as bugs do appear. Sometimes you have to press the Chromecast logo on the screen of the iphone and select the Horizon to make the connection.
Thanks for your reply! What about Chrome cast video? Audio seems to work as well. But video seems to be the problem.Chromecast is something that does work on mine. The communication between iphone and TV via Chromecast (Deezer) is ok. However I would give it not 100% yet as bugs do appear. Sometimes you have to press the Chromecast logo on the screen of the iphone and select the Horizon to make the connection.
