hi Mox
Did you resolve this issue
hi Mox
Plug the BeoSystem 3 or 4 into a TV and test it? At least that isolates the issue to the panel.
This is still ongoing, but managed to get a HDMI cable long enough to reach from the BV11-46 in the other room to the BS3 and it doesn't result in a picture on the BV11-46, which means it's likely to be a BeoSystem 3 issue?
I also tried connecting the BV12-65 direct to the back of the Sky HD box, but no picture (but not sure if the BV12-65 can receive a picture from its HDMI direct from the back of a Sky box?).
How easy is it to get a replacement BeoSystem 3?
I thought the BV12 used the Beosystem 4 not 3? Anyway, over this side of the pond Beosystem 3s are on eBay a lot, usually at around $1,000 or a tad more.
MK-1's used a BS3. And that's way too expensive for a very old device controller :) I'd save the $1000 towards an LG OLED 65" C9 which is, erm, $1000 more?
Hey, my only uncle was named Bob!
I guess viewed thru the cold lens of value, a grand for a Beosystem 3 might not be as good an investment as a new OLED set. Only makes sense if you're system is an integrated B&O one and you want that, a full Beolab based surround setup, as opposed to a Stage soundbar. Eventually you'll be forced to make the decision to abandon it I guess, or go full tilt with an Ecilpse or such, an expensive proposition.
I guess I've avoided merging my AV and stereo setups for that reason, I don't want to tie myself to B&O due to cost and reliability reasons for my AV setup. My stereo is pretty stable as is and I'm happy with my B&O setup. I could get a Beosystem 3 and a center Beolab, but what happens when it breaks?
Yours will be the later 3D version... These are pretty rare in all honesty.
Could you not box up your BeoSystem 3 and send it to an engineer to diagnose? It could be a simple fix!
Lee
Might be a wise idea as the call out fee is quite large. Problem is, finding a local engineer around Bath.
I *knew* it!
Well, the sad thing is, the BV12-65 is absolutely fantastic. Still prefer the picture over the BV11-46 in the other room (which seems much sharper/brighter). But fixing B&O kit is proving very very expensive in 2019.
Sounds like the case AS sith my BV7-40 MKIV just before the summer. Suddenly overnight only sound and no picture. No curtains, no menu, no picture on any source. Fan did not start when powering up. Local B&O technician found after conference with Denmark that the T-Con module was broken but could easily be repaired. Saved 400 EUR for a new one and only paid for the work.
That's good to hear - hopefully it's not too costly then. I really would like the BV12-65 back (before it goes off a cliff!).
