Hey everyone, I have my BeoSound 9000 connected to my BV11 via BNC, and overall, the control works fine, no matter which audio option I choose. However, I’ve noticed a few things: When I switch the source on the BV11 from BeoSound 9000 to TV, the BeoSound 9000 stays on.
Presumably the Beolink NL/ML converter (BLC) is set as VMaster. Then this reaction of the NL system is correct, because it is not aware if other ML devices are also linked to the BS9000.
Try to set it as ASlave (if the BS9000 is the only ML device connected to the BLC and/or no spreakers are attached)
When I turn on the BeoSound 9000 using the built-in buttons, the BV11 does not turn on. I remember this used to work in a pure ML network. Any ideas on why this is happening?
Same kind of argument. If set as VMaster and a button is pressed on the BS9000 the system/NL doesn't know should it start the BV11 or is it intended for the BS9000 with spearkers attached.
Also, the BV11 only shows the track number but not the CD number – a bit disappointing.
it looks like the BS9000 cd does not know which cd is playing, so it only communicate the tracknumber (also in B&o app, Halo). Still I'm in the impression the B&o app is designed to solve this in the future like it is solved with the use of the Beoconnect Encore..... see what the future brings....
Is there a workaround for this?
Not to my knowledge
Question about BeoLab 5000 integration: I want to reintegrate my old BeoLab 5000 speakers in another room using an IR eye. Ideally, I’d like the volume and track info to be displayed on the BeoLab 5000 screen. What’s the best way to set this up? Connect them directly to BNC? Or better to BeoSound 9000 as a secondary room product? Or do I need a BeoLink Active module to stay within the ML environment? Looking forward to your tips!
All options are possible, but not all option will show all the correct info on the BL5000. Be aware that extending the ML will make the VMaster option almost a necessity (see above).
😊 Best regards, Horst
