My dad is finally getting a BV11-40 on Thursday, and I would like to mount an AppleTV inside it, but I cannot find any information on what lengths the HDMI and IR cables need to be, so I can order these.
Can any of you guys clarify this??
The TV should come with two IR blaster wires.
The compartments on the BV11 are really intended for the wall hinge motor. There are several posts here where owners complain that their Apple TV's do not work reliably or need frequent resets if mounted inside the BV11........and if you search the Apple support site you will see that vertical mounting is not recommended because of how the components and heat sink(on top) are built.
Graham
A 1m cable is fine. However you will need a very thin cable to fit the Apple TV inside. Mine is triple shielded and just could not fit in. Instead I just used a Velcro tape and have it hung from the back of the TV. Works great with the floor stand.
Thanks for your replies. I was not aware that the compartment is intended for the hinge motor, that's interesting. I have heard a lot about this Apple TV compartment, but could not find anything about it in the user guide, but that makes total sense if it's not originally intended for it 🙂
I will buy a thin 1 meter cable.
Thanks again 🙂
I am using a stock apple hdmi cable. I guess it's around1,5 metres long and relatively thin. No issues at all. The ir cable is 7 metres long and also very thin. It all fits nicely in the compartment and works without issues.
Graham
The BeoVision 11 was originally supplied with an ir blaster with two emitters attached. This was changed recently and you now only get a single ir blaster.
Opman
I can confirm that only one IR blaster came with the TV.
Thanks for your replies. The TV now sits in my parents livingroom and my dad loves it 🙂
That being said, I wish my BV9 was so easy to add PUCs to. I still haven't come to terms with the fact that I need to pay a technician 1.500DKR (app. 200EUR) to update mine everytime I get a new device 🙁
I can never get my apple tv's to work after the latest firmware update
3 of them are now basically bricked !
Arguably the worst apple product ever imo !!!
What's the problem with them?
