Transferring/downloading is the first step.
Afterwards you must assign that PUC to the device/the ATV4K.
When the ATV is chosen as the source, it must look like on my picture in my earlier post, when you press MENU on the remote.
Thanks mate. I've just tried all that and keep getting confused when it asks for things like IR Blaster. I also ticked the box to "turn off source at standby" and tested it.. but the ATV doesn't turn off (light still lit) when I turn my BV11 off. The ATV seems to be permanently on (standby light lit).
I was hoping to avoid having to call the B&O guys out but looks like that is now my only option 🙁
On a separate note - my ATV is set to 1080p SDR 60hz in the 'Format' settings. Is this best for the BV11-46?
Thanks again for your help
