BV10 issues
Hi
My Beovision 10 has started acting up
It will switch on and the screen comes on for approximately 5 minutes then the picture splits in half.
Half the screen is still from whatever is on whilst the other half shows the current TV images then approx 5 minutes after the display disappears.
Last time it went blue.
Sound remains ok.
If I turn it ff then on again there is sound but no display.
If I leave it off a while it starts up OK again before going through the previous issue.
Any help appreciated.
Cheers Mark.
Doesn't sounds good. Have you updated the software to the final version? Perhaps worth a try. I downloaded it and installed via USB a year ago or so which updated the interface etc.
Is this when using the internal (inbuilt) freeview?
If not, what happens when you connect an external source, like a DVD Player or Sky Box?
Lee
Thanks for the reply.
No happens on sky, freeview and apple TV
all are connected.
I tried turning external sources off and using freeview only as the last attempt but it still occurred
