BV10 Connections?
Hello,
I have a BV6-26 connected to a Apple TV (1), and a Panasonic DVD recorder which for my current habits is OK, but I will need to upgrade at some pont in the future (HD, HDMI, Blu-Ray, etc), and today I think I discovered a first pointer into that direction:
I have previously only used the ATV for my music and movie trailers, but today I went to rent a film and couldn't as the film had HDCP and because the ATV is connected via HDMI -DVI via a converter it didn't work, I can't connect via component as my TV doesn't have the HD upgrade so these sockets aren't active.
So my basic dilemma is: A HD upgrade kit would be £600-ish (?) for my BV6, and is this money wasted when it would be better towards a newer/bigger TV?, however if I went down the BV10 route I don't believe this TV has a scart connection? so I then can't connect my Panasonic DVD to it and this then forces an upgrade of this unit also.
On a general note - Is Freeview HD out yet? If not do the current B&O tuners allow for it's future release?
Anybody have any suggestions?
Many thanks,
Ian
The BV10 has 3 scart and 3 HDMI connections.
The new DVB HD module will not occupy any of these and it's T2 and CI compatible.
BV 10 has 3 HDMI ONLY in MKII version.
In the 10-40 MKI there are ONLY 2 HDMI.
I had an issue with my ATV1 and HDPC message on my non B&O TV.  I found that when i changed the HDMI cable, it fixed the problem.  Have you tried another cable first? Before you head down the full TV upgrade.
Regards
Michael.
