Can any one help? I have a BV10-46 master linked to a BS9000 in the same room. Speakers connected to BV10, BV10 set in option 2 BS9000 in option 0. Link room TV option 6. How do I get timed radio to play through link room TV?
Steve.
Steve.
You must turn on the timer play funktion on the link tv.
On the BV 10 you can also turn on or off the timer function.
Stefan
Stefan
Steve.
Afaik BV10 has no timer function...(?)
Just Timer on/off
Just another...
...Stefan/Steve
Have tried to use BS9000 time function, will not allow me to program timer, it just displays TV enabled?
Hi Peter,This is normal message. The sound controls are setup from your BV, instead of your BS. The only way to set your soundsettings is via your television. You have to set timer to on and there you go. The optionsetting in your setup are right, so do not worry. Enjoy your system!If I try to change the sound controls etc via the BS9000 it displays 'tv operated'
