farfar wrote:
Did you associate an IR port with that connection ?
There were two options: IR or Plug, I choose IR
you made the correct choice
farfar wrote:
Did you get prompted for what PUC to use with that connection ?
No I just choose PUC1, because cable is plugged there
that is logical
farfar wrote:
Usually the "Apple Remote" PUC is under the list of "STB" (Set Top Box) PUCs and is called "Apple Remote"
When I use << >> I only see "B&O Test-Box" NO APPLE TV. Im I missing something or does the tv has to be coded with that option. It is a BV10-46 from August this year, the one with 3 HDMI connections.
So you cycled through the classes of PUC ("other", "stb", "dvd", "vmem" (VCRs)) and found no reference to "Apple Remote", and only saw "B&O Text-Box"
Sounds like your BV10 was not loaded with any PUCs which is unusual (for Australia)
In Australia they load the standard cable STBs (e.g. SKY) and also the "Apple Remore" you need
I suggest you wring your dealer
It does sound like they never loaded anything - I am assuming the "B&O test-box" is something the factory uses
