bv10-46: 2 or 3 HDMI?
I was told by my dealer that the BV10's currently being manufactured are updated in terms of connectivity and a 3rd HDMI is a result of this. He assured me that the 10-46 I have just ordered will be the later version with 3 HDMI sockets
Steve
hagan wrote:
I got my new 10-40 27th October. It has 2 hdmi
br
/h
Well, B&O homepage says 3... That's what I'm hoping mine will have once I get it...
Well, that's a non sense that B&O just makes an update only few months after the launch of the BV10 46", in a customer point of view. I feel a little bit abused...as mine (2 HDMI version)  was purchased on october 2010. I would have wait to get the 3 HDMI version "grgrgr"....*
Cheers,
Cheers,
I agree, I really hope mine has 3, because I remember reading on the B&O homepage when I ordered mine it had 3 hdmi inputs...
These new specs are existing since August. Check the user manuals available, there is a pre august (2 HDMI) and a post august (3 HDMI) release. But AFAIK, all BV10 46 delivered until now have only 2 HDMI built in, and the panel description behind the TV is the one from the pre august manual.
So b&o is misleading it's customers again... Just as they did with the early Beolab5's... Claiming they would work in syncro mode.
May I ask but what is a "syncro Mode" regardng the Beolab 5?
My new BV10-46 was installed last Friday and has indeed 3 HDMI inputs available.
According to my dealer there are some internal improvements as well. One was about the cooling of the LCD screen. I am quite happy with it as the "clouding"  is considerably less compared to my previous 10-40"
