Bv1 wake up
Mates
I have added a bv1/ml/nl converter to my large Ml network.
I use an mlgw for control via iDevice.
I can't get the bv1 to 'wake' from an mlgw command.
It responds when it is turned on, but will not initiate turning itself on with only a gateway command.
Any thoughts?
Turn on the wake on LAN setting. I think there is also a mlgw setting in the device menu. Power saving needs to be off as well.
Same problem with BV11. I have already disabled all power save modes and enabled wol.
Make certain you have enabled your quick start timers and also set the IP address of the tv. You'll be good to go then.
