My BV Avant 75NG shows strange behavior: it "looses" the satellite signal showing "no signal" (and of course black screen); if I do a hard reset (unplug) all the channels are back as if nothing happened; first I tried to redo the antenna but I think this behavior is due to a software issue which also might be connected to missing updates (android/google).
I was already thinking to reset the TV but than I get the even older software
does anyone have an idea how this issue could be solved?
My BV14 (should be the same software?) is running smoothly
best regards
Elmar
