Hi Michael
I have exactly the same issue as you have. At daylight this gap on top between screen and bezel is quite obvious. I allready informed me Dealer but no answer from B&O yet.
Please keep us posted as I will do the same. Otherwise I'm quite happy with the Avant and for me it is a very attractive package of sound, picture and B&O Magic.
good luck, Chris
Hi Chris!
Very interesting to hear! We should check our serial numbers, perhaps it is a bad batch? I also informed my dealer but have yet to get a solution to the issue. And as you, I like the TV but the issue is not very funny.
I do have one more issue with this Avant that wasn't a problem on my previous one and it is that the back aluminum plates vibrates if I play bass through the TV speakers. The metall pieces with damping material on is all bent and I think that is the issue with that.
The set also seems to have som clouding but it is very hard to reproduce, sometimes it is visible but it might perhaps be the local dimming acting up? I am not sure.
