BV 7 video by B&O
Dear All:
Does anyone know where I can find the video that B&O had of the BV 7 mrk III?
Thanks,
Dario
Thank you, most helpful.
Is there an LED light coming from the button used to release the disc tray? I know there's a light coming from the tray. I thought there was one emitting from the button that releases the tray.
Dario
No Dario, there is only LED on the tray, the button to open/close it has no light.
Dear All:
Is there a way to open the tray via the Beo4? If there is, I have yet to find it.
Thanks,
Dario
not really. If there is no DVD in the player and you push DVD on the remote, the tray will check for a disc and then open, but there is no other way to open it with the remote. Unfortunately!
