BV 7 says "WAIT"
My BV 7 shows "wait" in the top right corner (where the clock normally shows) and has a blank screen and won't respond to any commands from the remote.  Has it died?  Can anyone suggest a fix?
 TIA
Mark
Have you tried unplugging and re entering the pin code?
I've tried unplugging but all I get when I turn it back on is WAIT.  Shouldn't it prompt for the PIN?
Edit:  The screen is dead.
Has the PIN been entered wrong? This could be the reason....
Leave it in standby for 3 hours, the pin protection circuit will then be reset and will allow you to re-enter it.
Many thanks - waiting fixed it as you said it would. 🙂
