I wanted to tidy up some cables behind BV for a long time. I only disconnected the satellite box. When I reconnected it I had no sound so I turned off the TV and checked all the connections. The TV is not turning on , its almost like it was plugged out.
There is power to the socket.
Any suggestions ?
I did try the search function and found nothing.
