Hi
Does anyone have any info on the Blu Ray player specification inside the BV7 MkIV?
As usual very limited info on the B&O site.
I ma thinking specifically about up sampling and CD playing that is assuming it will play CD's.
Gofer
Hi
Gofer
As usual, a forum search is your answer (I'm wondering why people do not search).
Yes, it will play CDs and so on. Those specs were posted on this forum only last week!
Here they are under the rather subtle forum title of 'BV7-40 MKIV specs' !
/forum/general-discussion-and-questions/blgw-thermostat
They are also on the B&O website. Most important to your question:
Playback of the
following
BD-ROM, BD-R/RE, DVD-ROM, Audio CD,
CD-R/RW,(CD-DA only), DVD-R/RW
Thx. I did look!
forgive my ignorance but what is cd/da i know cd/r and cd/rw
malcolm
CD Digital Audio. ie. a standard audo CD.
ha hey RAT FANS !
Stopped in for a quick look at this thread and as I now know what it is about, I will not need to return to this thread as I am not interested in a Blu-Ray upgrade, but I am wondering why you find it so personally offensive when somebody posts a thread that in your sole subjective personal opinion is unwarranted?
Razlaw you're back! My personal moderator. I wondered when you you'd be back (as I was avoiding you ;)
Forums are supposed to be discussion points where you start a topic and then, well, discuss. Traditionally, if you want to ask a question that's been asked before, the first thing you should do is run a search to see if the queston has already been answered. In this instance, there's a discussion on BV7-40 MKIV specs on page 3 - a 15 second check or search would have answered the question.
If you want to encourage people to ask the same questions and start new threads - as you did in the other thread, where you looked for the discussions yourself and posted the links - then that's your perogative!
BTW "sole subjective personal opinion is unwarranted" sounds absolutely bonkers.
thank you moxey learn someting more everyday
malcolm
