BV 7-40 MKIII Link to BC 6-26
Hi all.
I'm going to buy the new 7-40 MK III when it's comes and I'm going to use the BC 6-26 as link tv in the bedroom. I just wonder if I can control the STB-C and harddiskrecorder from the bedroom via the link/BV 7-40? Hope you understan what I mean.
What cables do I have to use between the two tv's?
;-) Jes
Great choice.
Yes you'll be able to use the HD Recorder and the STB, if you are able to control then with the Beo4 in the main room.
From the link TV, you'll not be able to see the grey menu that appears when you are on the STC-C, but you'll be able to use the commands with the Go button. Go 1 = Menu 1
In term of cables, you'll need a masterlink cable and an areal cable. You'll also need a RF amplifier that you buy from B&O.
Great to hear about the beo5 and display. Just wonder if this will be possible: If someone is looking at the 7-40 will it then be possible to see the harddiscrecorder at the same time on the link 6-26?
Yes, the BV7 can distribute a source and show another one on its main screen.
Sound great! Thanks a lot for the fast answers!!!
;-) Jes
