Where do we find the new pricelist?
What kind of beamer do you use (brand and type) ?
Are you satisfied with the quality of picture?
The lack of a BV7-32 udpate (for now) isn't good news, I agree. Either they will have to drop the model or update it sooner rather than later. You can't have a BV8-32 with HDMI socket and 'old' BV7-32 with a DVI-only socket. Also, I'm assuming the BV8-32 screen is probably of a higher spec than that of the current BV7-32, as the chassis is digital-based.
Was in my dealer yesterday comparing the BV7-32 to BV7-40 and the BV7-40 is so much larger - the 7.2 speaker is nearly 25cm wider, which means that it could be too large for my apartment :-/
Hi, i do not think the dealers are permittet or even want to use it as a demo. Obviously they want to use the latest model for demo's - i mean if they are a good dealer 😁
I would think it easy to sell a used mk2 if you want to pay the difference. Here in Denmark a used 40 mk2 sells around DKR 55.000 in DBA where i can see that a new 40 mk3 will cost DKR 90.000 + remote (if Beo5 96.460 dkr).
