BV 7-40 Floor stand on BV 4-42
HI All,
Is it possible to use the motorized floor stand from a BV 7-40 on a BV 4-42 or BV 4-50?
As far as I know there is no outlet on the beosystem 3 for motorized stands, am I correct?
But is it at all possible to mount the screen at all?
Peter
Hi, I also want to find out if you can connect a beosystem 3 with a BV-40 stand.
Can anyone help or advise please, I see the Beosystem 4 has a connection for stand but no connection on the BS 3, but the BS 3 still has all the stand calibration software?
It’s just a small cable that simply plugs into the inside of the bsys3
bv4 will not fit, would need to find an STB bracket
Thanks, I will get one from my dealer :-)
I got the cable today for a BS3 to BV9 but can't find which board in the BS3 the cable plugs into :-(
Can anyone please help pinpoint the location.
Thanks in advance
Hello,
From the Hague Holland!
I have here a Beosystem 3 with Beovision 7 floorstand. Can you help me to connect them? Do you have a article-number or link where I can order this special cable?
Kind regards, Hilbert
