BV 7-32 MK V HDMI sound over Masterlink?
Hi everyone, I have a short question: can the sound of a HDMI source on the Beovision 7-32 MK V be distributed over masterlink? Or do I also need to connect analogue sound connections (e.g. via the scart).
Background: I currently own a 7-32 MK3 and play music through my AppleTV (4th generation) throughout the house using a HDMI > HDMI+sound splitter, but I would like to get rid of that device once I upgrade to a 7-32 MK V. There are too many converters in my TV cabinet. I have found in the reference manual on the B&O site only some statements about digital video and sound not being distributed, but that concern the older 7-32 models without HDMI. In the addendum of the reference manual that does concern HDMI it only states that the HDMI video cannot be distributed via the masterlink /RF amplifier, but that does not matter to me.
Thank you in advance, your input is much appreciated!
I’m fairly certain you have to use the analog connections to route audio through Masterlink and/or MCL to link rooms. That seems to be how my BS3 works.
My BV8-40 also routes my ATV’s HDMI Audio and my STB HDMI Audio over the ML.
I thought my other option was to buy a beovision 7-40 mk3 or higher, with the integrated Beosystem 3 inside to allow distribution of digital sources, but are you sure your beosystem needs the analogue connection?
You can not distribute digital connected (via HDMI) sources from a BSys3-based tv to the ML chain.
I also called some dealers and browsed some more on Beoworld: it appears there is no way to distribute the sound of HDMI sources over masterlink. Not with BS3, not with BV7-55 MK2, not with BV8 or BV10 - they all need a converter to de-embedd the audio from the HDMI. Only netlink products can do this (but delay, converters to Masterlink and to MCL... not worth it at all).
My best option is to get a HDMI matrix switch with audio de-embedder to have the correct signal, for example the already discontinued
Just to let you know: this is possible with a BSys4-based product.
New generation, new possibilities.
Here airplayed stuff to my ATV on my Avant and listening/joining in on my V1-32
I have a BV7-40 MKVI fed by an Apple TV 4 connected via HDMI only and able to distribute the sound to the masterlinked BL3500. Tested tonight. Condition is that the BV is showing the source, i.e. I cannot start the source from the link room
Best excuse to have a B&O setup in every room...
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I disagree wrt the BV8-40!
I am not sure of its level of “beosystem” sophistication. It had never occurred to me to ask. But the product was launched circa 2007 and then there was a firmware upgrade that added the hdmi audio to ML capability.
Like the others I retested before posting.
However to confirm here is some visual evidence !
ATV HDMI to BV8-40
BV8 ML to BeoSound 4
BV8 ML to BLC
BLC NL to Essence and also to Core
Case closed ?
