BV 7- 40 MKII or MKIII
Can someone Tell me if this BV7 is MKII or MKIII ?     Type No: 9376
        Item No: 1818900
        Serial No: 20943057
Thnx in Advance....
 I can't tell if it's a mark II or a mark III  (someone will be able to)...But the mark III is the one to have if your thinking about buying a Bv7-40 it's easy to tell as the display on the right is in white also has the Beosystem 3 in it with 4 Hdmi's on the back of it and you can up grade to add blu-ray and the new sound board to it later on. or just buy the new mark IIII thats coming out with it in.
Hope thats Helpfulish! And good luck.
Hej S,
Its a MKIII..
Already Own it , just checking because if thats the case going to upgrade it with a blu ray player;) Great to hear ;) Thnx ^^
