BV-6 Picture Format Question
yep this does work, you get a full 4:3 pic in the middle with black bars on the left and right side.
select "monitor" press [GO] and then you should be able to see "TELETEXT & FORMAT ADJUST"
Got it.  Thanks.
Did you ever get this to work? I face the same annoyance with my BC-6 and BV-7...
Toby
