BV-10 Smart card and CA module
Hi!
Just got my new Beovision 10 with dvb-hd. I´m trying to fit Ca module and smart card but cannot figure out what way they should be inserted. Haven´t got my usermanual and even looking at downloaded manuals doesn´t help me.
Can anyone guide me
br
/h
This hagan, this is the info from the Beovision10 user manual.
Insert the Smart Card in the CA module with the chip facing the front
of the module. Insert the CA module with the front facing away from
the screen. If the Conax Smart Card is used alone, the chip must face
the screen.
Hope this helps.
Tom
Thanks.
Worked perfectly
/h
