BV 10 Hidden menu
Hi friends,Hope you all are fine!Need your help please:Could you please tell me how I can get into the BV 10 Service Menu to view the various counters?I used to do it with my previous BV Avant 32" DVD and would like it for my BV 10-40 too.Thanks in advance. Cheers,
You can access the hidden menu the same way as on your Avant.
Thx mate!So if I'm not mistaken, the tip is:Menu set up 0 0 GoRight?
Put BV 10 in TV mode.
Press MENU, 0 (zero), 0 (Zero), GO and you can enter in Service Menù.
Simple.
Thanks November!cheers,
