BV 10 & Beomaster 5500 +
I wish to connect, control, play the 5500 and listen thru the speakers attached to the BV10.  I have the ML/MCL Converter anything else neccessary (ie PUC) or I need to do, to listen to the 5500?  Thanks.
Just plug in the ML cable from converter to tv, and the AUX cable from Converter to AUX-in on the 5500-master - without power connection to any of the devices.
Remember: first turn on the power for the tv and the audio-master before you power on the converter.
Put your tv in option 2 and the audiomaster in option 0 - see manuals or ask again.
All sound is now routet to the BV10. All audio-commands are now received from the BV10 and routet to the 5500.
Greetings Millemissen
Well I have sound in one speaker when playing the 5500 and both when playing the TV.  Any suggestions?
